Golf Cart blows headlamps
Y
Yzordderrex
My coworker told me that halogen headlamps blow on his golf cart. He
asked me if there was something he could do to mitigate.
I did a little research and found the bulb has a filament. I told him
a NTC thermister may reduce surge at power on and help to prevent
this.
Am I on the correct track? Any other ideas?
regards,
N9NEO
S
Spehro Pefhany
All indcandescent bulbs burn out eventually. Presumably you mean they
die faster than the rated lifetime? (Probably low triple-digit
hours).
Power-on surge is unlikely to significantly reduce the life. It just
seems like that because they tend to fail at power-up when they were
about to go anyway.
What voltage is the electrical system on the golf cart? What is the
filament voltage of the lamps?
Michael's idea is the #1 thing. The actual voltage on the bulbs
compared to their rated voltage. Higher than rated voltage greatly
reduces the life.
Sometimes people use a voltage reducer module so they can use cheap
12V bulbs on a 36V or 48V system. It's possible they fail with HV out
if they're a buck converter.
Vibration doesn't help either.. and lower voltage lamps tend to have
sturdier filaments.
M
Martin Riddle
this.
regards,
N9NEO
Keep finger oils off the bulb, if it not in a sealed enclosure. This
shortens the life span quite a bit.
Halogens can last quite a long time even with rough handeling.
Now on the other hand, those mini Krypton maglite 2AA cell bulbs are
fragile.
Cheers
O
OldGuy
this.
regards,
N9NEO
And do not drive on bumpy roads with the lights on.
Change to LED lamps.
What is the ANSI number of the headlamps? Usually this will be a
three-digit or four-digit number, maybe with an "H" on the front. This
will enable you to find the rated voltage, rated lifetime, etc. It also
allows you to see if a "long life" version of the lamp is available.
If this isn't already happening, buy lamps from a reputable manufacturer
like General Electric, Philips, Wagner, or Sylvania. If it is a 12 V
lamp, try the local auto parts stores for a good selection.
reduces the life.
Agreed. It might be interesting to hook up a voltmeter at the lamp
terminals and check the voltage both standing still and while driving.
The golf cart may regenerate into the batteries when coasting, which
tends to raise the system voltage; depending on how the lamps are
powered, this may also raise the lamp voltage.
Also, try not to have the headlights on when the golf cart is plugged in
to the charger; this may also raise the lamp voltage.
Or, the manufacturer just wires the lamps across the "first" 12 V
battery in the string. This is OK when the battery is being
discharged, but might lose when the battery is being charged - it
depends on the charging voltage.
It may be worth checking to see if someone has replaced a rubber or
spring mounting with a solid mount. You will probably need a parts
diagram for the golf cart or assistance from a dealer to figure this
out for sure.
Matt Roberds
G
gregz
this.
regards,
N9NEO
Gas or electric ? My gas does some flickering. Got LEDs.
Greg
josephkk
this.
regards,
N9NEO
Maybe. Sounds like really out of specification transients are escaping
the motor control system and getting to the headlights. Automotive
headlights are generally pretty tough and can handle lots of guff, but the
kicking they are getting is well beyond specification.
