GM digital dash
Discussion in 'Electronic Repair' started by BOB URZ, Feb 10, 2005.
  1. BOB URZ
    BOB URZ Guest
    Has anyone here attempted to repair a 90's GM digital dash unit?
    From what i can research, they have a small power inverter board
    as well as the typical bad solder joints in them. My brother in law
    is bringing his over and i am trying to prepare. Anybody been inside
    one?
  2. Art
    Art Guest
    Pull the dash assembly, call the local GMC Service Facility, ask what the
    exchange price is for the item, and bite the bullet. Most of these
    invertors, etc are priority parts available only from the supplier to the
    manufacturer of the vehicle.
  3. Jerry G.
    Jerry G. Guest
    Most of the parts are priority type parts in these. You will not be able to
    buy most of the parts on these boards. If it built up on a flex board, even
    fixing a cold solder connection will be difficult. The only fix is to pull
    it out, take it to a GM parts dealer, and pay the exchange for a new one.
    This is the same for all of these cars.
    Jerry G.
    one?
    ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet
    News==----
    http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+
    Newsgroups
  4. Bob Urz
    Bob Urz Guest
    Come on guys, someone has tried to do this somewhere. There are a number
    of internet sites advertising dash repair. And since GM does NOT sell
    parts to do this, they have figured out how. Basically, these dashes
    have a step up power supply to run the display tubes. Not brain
    surgery, just a switcher and some parts. And i am guessing Jerry that
    your right and there house numbered parts. But that does NOT mean
    there not fixable. Once you know what the circuit does and the case
    style of the output device, one can probably make some assumptions
    and go to a parts catalog and try a few devices. Hell, it might just
    be caps with bad ESR or solder joints. Other people are doing this.
    Granted, customized CPU chips or ASIC would be a problem. But i believe
    in the older dashes its just solder joints and power supply problems
    for the most part.
    So no, i am an not going to tell my Brother in law to junk a car that's
    probably not worth much more than a $800 digital dash (if its even still
    available). Its worth a shot to figure it out. And maybe if i do,
    i will offer that service too along with my other repair services.
    So i ask again, any other braves soles actually dig into one?
    Once i get it and dig into it, i will report back.
  5. Hi!
    I'm sure somebody has, but around here these things exist only in the print
    of the manuals for the car. Other than in very new cars where such a thing
    might be standard issue, I have never seen one.
    Maybe such dashes in older cars are rare enough that the few people who know
    how to fix them or have bothered to take them out and have a look are either
    keeping to themselves or doing the repair for profit.
    Well, you're never going to know unless you take it out of there and have a
    look at it. Worst case you find that it's somehow potted or uses really
    oddball parts.
    I suppose locating a working example of the same or a similar dash would
    also be a good way to learn. You could make measurements and see what the
    circuitry is doing where.
    No, but if I ever happen to see one in an older car (and preferably in the
    junkyard) I will take it out and look at it. I'm looking forward to hearing
    your report on these.
    William
  6. James Sweet
    James Sweet Guest
    What sort of tubes does the inverter run? If you have an idea of what sort
    of voltage they require it shouldn't be too hard to put something together,
    I've built DC-DC coverters based on the MAX771, as well as small self
    oscillating converters.
  7. Art
    Art Guest
    It will be very interesting indeed to see the reverse engineering repair for
    these infernal items. I would also presume that GM Technician Centre in
    Warren, Michigan may be of some interest if an inexpensive, after market,
    viable repair can actually be preformed without involving any parts from one
    of their suppliers. Please, Do keep us posted. Dying to see your specific
    results.
  8. Bob,
    I used to own an '86 Cadillac Seville with the digital dash. I had a problem
    with the dash being out. My problrm was in the Delso Central Power Supply
    (16058596). It was located under the dash, and feed power to the display.
    From my notes (4/1996):
    CR2, Power diode, marked 9145B T8533, shorted, replaced with 1N4725 3A/1000V
    Also found bad solder connection at 8 and 16 pin DIP IC.
    I don't have any more info. Hope this helps.
  9. Phil Bowser
    Phil Bowser Guest
    I have no exp. on the GM, but let me know how you fare, and I am
    currently working on my 1990 Dodge Ramcharger "Electro-mechanical"
    speedometer unit... It has a 20-tooth cheap plastic gear that is so brittle
    the teeth are breaking off (happened in cold weather) for the odometer. I
    would much rather repair it than buy an exchange hard-too-find, and equally
    unreliable replacement part... whatever happened to brass (or even teflon)
    gears?? I cannot believe something was made this cheaply for an automotive
    application... I've seen microcassette decks, VCR decks, etc. with much
    better gears in them (unfortunately for me, not the right SIZE).
    This particlular speedo unit uses +12V, GND, and a 5Vp-p square wave
    pulse from the distance sensor on the xmission...
    A coworker has a GM digital dash that the speedo fails to
    illuminate/display anything... I will be looking into it within the month...
