R
Robert Latest
D said:I have about 12sq ft of single clad PCB in my junk storage.
With photo resist, or do you use the spray type for that? Never worked for
me ... back in the days.
robert
I'm thinking of glueing single sided PCB's together 2"x4" to make a
double sided board.
I have:
2 part epoxy
polyester resin + hardener
anaerobic adhesive (threadlocker)
2 part Methacylate adhesive
Automotive gasket sealer
Which is best?
Should I order some special glue instead?
If needed I can cure it in the kitchen oven..
My lesser choices were:
Superglue
Contact cement
RTV Silicone
urethane
krw said:I did a LOT of this when I was in college.
We had a lathe that turned out single-sided boards from copper-clad.
Keith
I'm trying to imagine how that worked.
I'm thinking you meant *mill*.
robert
0.032" total thickness...floppy stuff I have about 12sq ft of single
clad PCB in my junk storage. But my projects are often 2 clad..
Hence..the glue idea..
mpm said:First of all, I think pop-rivets get undeserved bad press!
Maybe if they called 'em "Miracle Rivets" or "Oxy-Rivets?"
(Nevermind, that's a Billy Mayes TV flashback - That guy would sell
his mother!!.)
I think pop-rivets are God's gift to engineers. (You can quote me on
that!)
Of course, it could also explain why they won't let me back in the
Shop anymore...
...unless the polyurethane foam packager gets clogged or goes off
line, and then all of the sudden I'm McGuyver or something.
I don't think you can be McGuyver, unless you use
duct tape.
I've made a "PC board" using contact cement, wooden
board, and copper (roof) flashing. The "traces" were
strips of the flashing, individually glued on. Never
tried making a double sided board by gluing two single
sided boards together, but I'll bet contact cement
would work great.
Ed
ehsjr said:I don't think you can be McGuyver, unless you use
duct tape.
would work great.
I had a PC board with a hole about the size of a quarter burnt away.
I used some scrap aluminum to cover the hole, and Bondo to fill the
hole.
No, I mean a lathe. Think about bending the copper-clad into aI'm trying to imagine how that worked.
D said:My leftover pcb material has no photoresist..
I use presensitized PCB material for my 1206 level SMD work.
And why don't you just buy dual-layer photosensitized material? Mind you,
I'm sure you have a good reason for wanting to paste together two
single-layer boards (seeing how obvious the dual-layer solution is); I'm
just curious why you want to take that route.
Personally I'm happy to have chucked all that yucky home-etching stuff out
of my basement. But of course twenty years ago I couldn't have afforded
professionally-made prototypes, especially since my layouts were hand-drawn
in black ink on vellum. Occasionally double-sided, too.
robert
hole. After it cured I straightened out the copper foils and glued them
to the Bondo. I drilled new holes, and replaced the bad parts. The
board was still in almost daily use several years later.
Next thing you know, they'll be publishing the dielectric properties
of Bondo!
D said:I have about $100.00 in useless leftover single clad.
In my app, the bottom layer is mostly ground plane. I might not even
have a pattern on that layer..just holes.
Thermal reliefs might be nice but I can brute force solder..
I might not need photoresist or etching for the bottom PCB..
Also..the material I have is too floppy @0.032 for my app...Doubling
it will make it just right.
Jim said:At TEK,I used to Dremel out the burned area of PCBs,place cellophane tape
over the hole,fill with epoxy,and put it in the drying oven to
quicken the cure.Then I would use a grinding burr in the Dremel to level
out the top side,and drill for eyelets,repairing the tracks with salvaged
copper traces and pads or from a PCB repair kit. I never did one as big as
a quarter,though.Maybe 1/2 inch tops.
I used a Hysol optical clear epoxy,608,IIRC.(TEK stocked that epoxy.)
Now I keep a RAKA boat-building epoxy kit handy,plus fumed silica filler to
thicken it. you can get glass fiber fillers too.
If I were doing this, I would tape plastic sheeting to both
copper surfaces, to prevent getting any epoxy fingerprints
on them, and then paint both with epoxy, stack, weight over
disposable surface like newsprint, and let cure. Epoxy
oozing out all around would be good, just an indication that
no voids were left between the boards. Removing the taped
cover would also remove any extra epoxy.
System Three has a nice inexpensive epoxy sample kit complete with an
assortment of fillers like fumed silica,plastic microballoons,wood
flour,chopped plastic fibers;the last time I checked,the cost of the kit
was $10 US PPD.
There's more than enough to do several PCBs.
Plus you get the Epoxy Book,a very useful source of info on epoxies.(it's
also downloadable)
Get some 1 oz.graduated cups from the drugstore or WalMart to mix up small
amounts. They are very handy. Oral syringes are useful for small batches.
