Glue orvarnish for air coil windings?
Discussion in 'Misc Electronics' started by Wim, Nov 13, 2004.
  1. Wim
    Wim Guest
    I want to glue or varnish the windings of an air coil. The coil is
    made of coated (polyurethan) copper wire.
    Which is the best glue or varnish?
  2. exxos
    exxos Guest
    a few coats of polyurethane varnish works well for me.
    Chris
  3. Jim Weir
    Jim Weir Guest
    Dissolve a chunk of polystyrene plastic in acetone. Use as much polystyrene as
    the acetone will take. It should come out the consistency of pancake syrup and
    dry within a few minutes when you coat a coil with it.
    Clear fingernail polish will work almost as well. As will PVC cement.
    Jim
    (Wim)
    shared these priceless pearls of wisdom:
    ->I want to glue or varnish the windings of an air coil. The coil is
    ->made of coated (polyurethan) copper wire.
    ->Which is the best glue or varnish?
