P
Pawel Paron
Here is my another experiment with overpowering an MH bulb: Osram HQI-T 250
W/D powered with a 400W coil ballast (using its 240V terminal instead of
230V, so lamp power is slightly less). I run this test yesterday, all was
fine for couple of hours (it's in my DIY projector), nice bright picture and
colours, then I closely inspected the bulb after cooling and didn't notice
any signs of visible wear or damage. But this morning I tried again, and
there was trouble starting the lamp, I saw a weird blue glowing through the
projection lens, so I took a look at the bulb, and this glowing was not
inside the arc tube, but around those wires, that support the arc tube. Like
in the neon tubes, a steady blue light along the wires. I've never seen it
before, although I had some problem lamps, that didn't start correctly, the
striking was always inside the arc tube. But here there is no abrupt
striking, but a steady discharge, a blue light about 1mm thick along all the
lenth of those wires inside the outer envelope. Finaly this lamp started
after a while, and I had no time to test it again, but I wonder if it might
be a sign of a lamp damage, or maybe ignitor? I expect, that ignitor would
generate short pulses, so what would be this steady neon-like glowing coming
from?
Regards
Pawel
ps. yes, I know all the warnings about overpowering gas discharge bulbs
from?
Regards
Pawel
