I think you need to do some real residential installing Frank. I have seen
*every* glass break fielded false in a home situation, even the newer high
tech ones. Teenage girls girl screams are real good at it, as are dishes,
percussion practice, snapping on the front panel of computer cases, pool
tables in rumpus rooms, and the Matrix or Dune on the HT.
Let's see... of the hundred's of 730 series glass breaks we've got out
there I can confidently say we've had *zero* false alarms. I don't count
the time one customer's son broke the living room window with a base ball...
The sensor performed flawlessly and did exactly what it was supposed to.
I've got the Matrix and Dune in our movie room... Along with an FG730...
I'll crank up the amp next time I watch them and get back to you. I have a
customer that has a daughter in a band (she plays the drums). They practice
in their garage and that has a FG-1625 mounted on the ceiling... No
problems... Dropping a dish or glass on the floor *can* result in an alarm
(or so I've heard)... I guess if you stomped on the floor at the same time
that the glass broke, it would go off, but then you *are* meeting all the
sensor's detection parameters aren't you?
We program the zone depending on where the glass breaks are installed.
Unoccupied basements are set up differently than the HT area. Houses with
teenagers programmed differently than a retired handicapped couple. I
assume others here do something similar.
I agree the environment plays a huge role in how any detector should be set
up. I've yet to see an Intellisense FG series detector false from any of
the things you've mentioned (including rattling your keys)...
