Getting 24V from a 5V sensor output
Discussion in 'Sensors and Actuators' started by Salik Hassan, Mar 25, 2017.
  1. Salik Hassan
    Salik Hassan
    Mar 25, 2017
    How can I get 24V signal from a sensor output having pulses of 5V?
  2. ramussons
    ramussons
    394
    75
    Jun 10, 2014
    If you are meaning a 24 volt Pulse from a 5 Volt Pulse, I think a simple Transistor/FET amplifier should do the job.
    What are the Sensor Output Specs? Pulse Frequency, Rise and Fall time?
  3. Minder
    Minder
    3,182
    690
    Apr 24, 2015
    A logic level Mosfet, a small one is the 2n7000 up to 200ma.
    M.
  4. Minder
    Minder
    3,182
    690
    Apr 24, 2015
    Incidentally if the 5v sensor is open collector then you would need a ~10k pull up resistor to use with a FET.
    M.
