[email protected]
Is it safe to assume that all diodes with a glass enclosure are
germanium? I have a 1N3600 for example with a glass enclosure. Is it
silicon or germanium? I guess I could check the forward voltage
drop ...
Why are glass enclosures used?
When a glass enclosure is used, is the junction shielded from outside
light since light has an effect on the diodes reverse saturation
current?
I am trying to experiment using a common glass diode as a photo
diode. I want to reverse bias a glass diode and try to measure the
reverse saturation current with a DVOM set on micro amps. I know that
there are photodiodes designed for this but just for giggles, I wanted
to see what would happen with a glass diode.
Any help would be greatly appreciated. Thanks
drop ...
current?
