S
Stuart Brorson
Hello!
This is to announce the release of gerbv-2.0.0! Gerbv is an open source
Gerber file (RS-274X only) viewer for Linux and other unix flavors. Besides
viewing Gerbers, you may also view Excellon drill files as well as XYRS
(pick-place) files. For more information, browse to gerbv's web site:
http://gerbv.sourceforge.net/
Gerbv is allied with the gEDA Project, an open-source collaborative
which has produced an end-to-end tool chain for PCB design on Linux and
other unices. The gEDA Project's website is here:
http://geda.seul.org/
Gerbv release 2.0.0 represents a a whole new look for gerbv. Most
importantly, the layer control GUI has been made much more powerful through
the outstanding work of Julian Lamb. Julian has also re-worked the GUI's
button and menus to make them more convenient to use. We are certain that
you will find gerbv-2.0.0 even easier to use than before because of Julian's
amazing work!
Other changes include:
* Julian Lamb incorporated the cairo graphics library into gerbv,
thereby enabling export to a variety of different output file
formats, including PDF, PS, SVG, and PNG.
(GDK rendering remains available as a configure option for
older Linux systems.)
* Cairo rendering also supports "transparency mode", showing you
which layers are underneath other layers.
* Drill parser rewrite by Joerg Wunsch giving better support for
internationalization and formats.
* Added report windows showing statistics of Gerber and
drill codes used (as well as CAM errors) by Stuart Brorson.
* Parser improvements from Stefan Petersen and Julian Lamb.
* Aperture handling improvements from Stefan Petersen.
* A new unit test suite (and nightly test runs) by Dan McMahill.
* Improved autodetection of file-type by Stuart Brorson.
* Improvements in the graphical rendering of pick-and-place files.
* Export of images from the command line (cairo only).
* Complete implementation of the Gerber spec.
* Open multiple layers at once in File->Open dialog.
Gerbv's homepage is on SourceForge:
http://gerbv.sourceforge.net/.
There you will find a bug database, a feature request database, the CVS repo
and a commit mailinglist.
To download gerbv-2.0.0, go to
http://prdownloads.sourceforge.net/gerbv/
and grab gerbv-2.0.0.tar.gz
To install gerbv do this:
1. tar zxf gerbv-2.0.0.tar.gz
2. cd gerbv-2.0.0
3. ./configure
4. make && make install
Interesting configure options are:
--help : Lists all configure options.
--disable-cairo : Use GDK only for graphics rendering.
--disable-exportpng : Disable compilation of export of PNGs.
--prefix=<dir> : Install to dir <prefix>.
--with-maxfiles : Set maximal number of files (default 20).
--enable-unit-mm : Change default unit in status bar to mm from inch.
Thank you for using gerbv-2.0.0!
-- The gerbv team
amazing work!
2. cd gerbv-2.0.0
3. ./configure
-- The gerbv team
