"Geovision" GV900-8 Capture Card (240 FPS) DVR
Discussion in 'Security Alarms' started by Bernard, Oct 29, 2003.
  1. Bernard
    Bernard Guest
    folks what do you think?
    the spects looks good (it does 30 FPS/ camera) and i can get a pentium
    4 2.6GHz for about $600.00
    pro? cons?
    thanks,
    Bernard
    Input Type.....BNC 15 pins D-Sub connector
    Video Input.....8 Cams
    Audio Input.....4 channels
    Recording Rate.....240 fps (NTSC), 200 fps(PAL).
    Display Rate.....240 fps (NTSC), 200 fps (PAL).
    Video Resolution.....320x240, 640x240, 640x480, 640x480sw
    Compression Format.....Wavelet, Mpeg-4
    Networking.....LAN, TCP/IP, ISDN, PSTN, ADSL
    Backup Function.....HDD, CD-R, DVD, MO, ZIP
    System Requirements
    OS Support.....Windows 2000 / XP
    CPU.....Pentium4-2.6GHz(800 MHz FSB)
    RAM.....512 MB (minimum)
    HDD Size......120 GB (recommended)
    VGA Card.....Nvidia, GeForce ll MX200 64MB
    Major Features
    - 640 X 480 recording and display resolution
    - Mpeg 4 / Wavelet compression technology
    - Motion detection, around the clock, and pre-schedule recording mode
    - Alarm to E-mail (Jpeg or text message)
    - Embedded I/O devices control
    - Embedded PTZ control panel
    - Build-in web server
    - Digital watermark authentication
    - Multi level passwords protection
    - Full screen display
    - Support dynamic IP address
    - Video lost detection
    - On screen video lost message
    - Support dual screen display
    - Video de-interlace filter
    - Video auto gain controller
    - Video scaling filter
    - Use Microsoft Remote Desktop to control another GV-System
    - Mini-View display
    - AVI repair utility
    Recording Mode
    - Motion detection recording
    - Around the clock recording
    - Pre-schedule recording
    - Pre alarm and post alarm recording
    - Pre motion and post motion recording
    Camera Configuration
    - Independent video brightness and contrast control
    - Selectable motion detection sensitivity and masking area for each
    camera.
    - Independent recording quality and frame rate adjustment.
    Remote Monitoring Software
    - Remote View
    - IP Multicast
    - WebCam
    - Remote Playback system
    - Geo Center
    - G-View for Win CE PDA
    - i-Mode
