Genius! Please tell me the theory which apply on this
Discussion in 'General Electronics Discussion' started by ranatungawk, Dec 2, 2012.
  1. ranatungawk
    ranatungawk
    10
    Aug 5, 2010
    I found this circuit in a cheep rechargeable LED touch. However, as far as I could understand, I saw an issue of this circuit (other than the safety issue). So genius! Please tell me what I think on this, is correct!!
    In order to drop the voltage, a Mylar Capacitor is used. Further, the Ni-Cad battery (3.6/700mA) will be charged with 4V/70mA source. However as we know, when the battery-charge go up (after 1-2 hours), the drain current from the source go down (<70mA). However, at the start, the charging current and the voltage was calculated according to “V=IR” and then a capacitor was selected in order to fulfill the above charging-values. So according to this argument, after 1-2 hours, charging voltage on the battery must be high than starting 4V (Ex; if I=30mA then voltage on the battery should go up to 134V). can this be happened ?? Can it make any harm to the battery?
    Please see the attach diagram
  2. Raven Luni
    Raven Luni
    798
    8
    Oct 15, 2011
    Nice recipie for an exploding battery.......
  3. KrisBlueNZ
    8,393
    1,270
    Nov 28, 2011
    Many people here will not help less-experienced users with circuits that have outputs that are not isolated from the mains. This is because we don't want you to electrocute yourself. We can't stop you, but we don't want to have been involved in any way.
  4. BobK
    7,682
    1,686
    It is s trickle charger at 0.1C. The voltage will only have to rise a small amount to keep 70ma goling through the battery indefinitely.
