Generators/Solar Cells in series or Parallel?
Discussion in 'General Electronics Discussion' started by Haxor, Mar 28, 2012.
  1. Haxor
    Haxor
    12
    Mar 28, 2012
    Hallo everyone.
    Im new here at electronicspoint, i have something in mind that i would like to try out.
    now i understand i can add batteries in series and parallel so as capacitors but is it possibile to add solar panels in series or parallel? and generators aslo?
    would the concept of batteries and capacitors also apply to them both?
    series: increase voltage?
    parallel: increase current?
    and do is the wiring the same?
    - Sammy
  2. (*steve*)
    25,480
    2,828
    solar panels are often connected in series or parallel. But like batteries, the weakest cell essentially determines the output current or voltage. Most solar panels are actually a collection of cells in a series/parallel arrangement. With batteries, a weak cell can get hot or damaged, with solar panels a panel in shade can get hot or damaged.
    Generators are often connected in parallel. Think o your typical power generation plant. It effectively puts all generators on the grid in parallel with each other. You have to take very careful steps to ensure that they remain locked in phase with each other. In theory you could do the same with generators in series, but nobody ever does (AFAIK).
  3. Haxor
    Haxor
    12
    Mar 28, 2012
    I'll probably stick to parallel i need a high current output. But how can I ensure they remain locked in phase?
    and im planning on wiring them the exact same way as these capacitors here in parallel:
    [​IMG]
    is that the right way?
  4. (*steve*)
    25,480
    2,828
    You're connecting generators in parallel?
    You need to precisely control their speed so that the shafts turn at exactly the same speed.
  5. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    can you imagine 3 240v AC generators all passed through a diode and rectified and then placed in series...... Jacobs Ladder anyone? :D
  6. Haxor
    Haxor
    12
    Mar 28, 2012
    Yes, hopefully i'll maintain the seed of the shafts going at the same time.
    I'll try series after i'm done with the parallel ones and see whats best.(i think its parallel but well'c)
  7. Haxor
    Haxor
    12
    Mar 28, 2012
    no worries their not rated at high voltages. Im testing this with lower voltages generators to avoid any danger or major damages until i understand how it works then try it out on bigger generators and the chance that i'll wire them in series is highly unlikely.
  8. twister
    twister
    172
    7
    Feb 12, 2012
    You can't hook two AC generators in parallel unless they are in phase, or you will have two burnt out generators!
  9. Haxor
    Haxor
    12
    Mar 28, 2012
    If you mean by the speed of shafts they will hopefully going the same.
    If you mean the type of phase their all 1 phased.
    And finally I'll be working on DC generators at lower voltages from 12 - 24 MAX.
    to avoid problems and they are what i have available right now.
  10. (*steve*)
    25,480
    2,828
    Not just speed but exact position.
    If you marked the same position on each, they would need to remain tightly in step with less than half a degree difference.
    This is done in power stations, but pretty much nowhere else. Unless you're talking about megawatt sized generators, they're unlikely to have the ability to do this.
    DC generators are less of a problem. Isolate them with diodes and you will have fewer difficulties putting them in parallel. In series it's a slightly different matter.
  11. Haxor
    Haxor
    12
    Mar 28, 2012
    where should I place the diodes? directly with the generators output?
    what other difficulties should i consider? i will place the generators in different directions their close to one another but not the same direction could that be a problem?
  12. Haxor
    Haxor
    12
    Mar 28, 2012
    is it possibile to wire the generators like this:
    [​IMG]
    But I have more then one generator so this can go on and on right? And I will add a diode on the + side of the generators as "Steve" said to do.
  13. (*steve*)
    25,480
    2,828
    For a really technical answer, look here. (You want section 20, about half way through)
    But I think it's likely that you're not planning on running a power station.
    I would recommend appropriately rated diodes between the +ve output and your cable marked as "To +12V"
    These will drop between 1 and 2 volts, but will prevent one generator from trying to drive another one.
    However it won't prevent one generator from trying to hog the load. And that may be harder to do, especially considering the way you're wiring the generators. At the very least you should take a separate (same length) lead from each generator to a single point.
  14. Haxor
    Haxor
    12
    Mar 28, 2012
    well the generators will be close to each other i'll try to give them a bit more space and see how it goes on.
    I'll also add diodes between each generator to avoid what you said.
    But i'll test it out and see whats the outcome if i can solve the problems thats fine if not i'll be back and give you all the update.
    -Sammy
  15. Haxor
    Haxor
    12
    Mar 28, 2012
    yea the links not working
    and the voltage drop will it effect the current as well?
  16. Haxor
    Haxor
    12
    Mar 28, 2012
  17. (*steve*)
    25,480
    2,828
    I've fixed the link
  18. Haxor
    Haxor
    12
    Mar 28, 2012
    Um... sorry Steve its not working still.... 404 error keeps coming up
  19. (*steve*)
    25,480
    2,828
    Weird. Don't worry it's not particularly relevant.
  20. Haxor
    Haxor
    12
    Mar 28, 2012
    ah ok...
    Im starting to draw the schematics for my circuit now and i will work on them soon. Thanks Steve for the help so far. I'll keep this post updated from my progress hopefully i'll achieve a good a perfect output and will answer this post by my own let it be an experiment.
    - Sammy
