Generating 9V @ 10mA - isolated from supply battery
Discussion in 'Hobby Electronics' started by JERD, Oct 16, 2007.
  1. JERD
    JERD Guest
    I have a need to generate 9V at 10mA that is totally isolated from a 12V car
    battery. That is no common negative connection between the car battery and
    the negative of the 9V supply. Any pointers on how I can do this would be
    appreciated!
    JERD
  2. Buy a 9 volt battery?
    Dorfus Dippintush
  3. chris
    chris Guest
    Depending on how much you want to spend (low power will be cheaper), you
    could use an isolated DC-DC converter eg Farnell sells a Traco TEL
    2-1212 9-18V in 12V out 2Watt for about $35.
    A linear reg on the output can get you to the 9V since a ready-made 9V
    output is less common.
    HTH
    Chris.
  4. Franc Zabkar
    Franc Zabkar Guest
    Scrounge a 5V-9V DC-DC converter module from an old 10base2 NIC and
    step down the input using an LM7805.
    - Franc Zabkar
  5. Andy
    Andy Guest
    How about using the SRS-1209 listed on this page:
    http://www.computronics.com.au/meanwell/srs/
    Problem solved for under 8 bucks...........
    Andy
  6. Farnell have a whole range of isolated DC-DC converters.
    102-1604 for example is a 12V to 9V isolated converter @ 111mA.
    Bit pricey though.
    You could use a cheaper 12V-12V one and use a 9V regulator on the
    output.
    Alternatively, use a battery.
    A D cell battery pack would last several months at 10mA continuous.
    Dave.
  7. JERD
    JERD Guest
    Thanks for feedback guys. Most helpful and I now have some options!
    JERD
