Gen HV spike audio
D
David King
What is the simplest, most accessible way to generate a 300-400V
spike, continuously adjustable within the frequency range of 200Hz to
2KHz? I am doing exps with powering a 20W industrial gas lamp.
David King
P
Phil Allison
"David King"
** Do the spikes need to be all of one polarity ?
If bi-polar spikes are OK, then try driving a small mains transformer
connected in reverse sense to normal ( say 12 volt to 240 volt ) with a
differentiated square wave that is varied between 100 Hz and 1 kHz.
You will need an audio amp like the TDA3020, a 555 to generate the square
waves and coupling cap chosen to get the right spike energy.
....... Phil
