Gemini P3200, Locked myself out
Discussion in 'Security Alarms' started by Craig K., Nov 20, 2003.
  1. Craig K.
    Craig K. Guest
    I have a Napco Gemini P3200 that I installed myself a few years ago. I
    recently decided to add another keypad. I assigned one keypad as 1 and the
    other as 2. I figured out that I also needed to tell the system that I have
    two keypads installed for it to recognize the second keypad.
    I guess that I knew just enough about programming that I did something that
    I should not have. Instead of telling the system that I have two keypads in
    area 1, I think that what I did was assign keypad 1 to area 2. Area 2 does
    not exist in my system. Now I can not access ANYTHING from EITHER keypad.
    They are both "Out of System". Keypad 2 has not been defined in the system
    yet, and now my programming keypad, keypad 1, is set up for an area that
    does not exist!
    I recently purchased the Namco Quickloader software thinking that that would
    be the way to solve my problem. It won't connect to the panel. I don't
    know if it is something with my modem and connection set-up, or if the panel
    is not connecting because it is messed up. I am using one phone line in my
    house to try to dial into the alarm phone line.
    I really don't want to have to clear out the whole panel and start again.
    Besides, I don't even know if there is a way to do a hard reset on this
    thing even if I wanted to.
    Any thoughts? Would a direct connection work? I don't have that hardware
    piece to connect my laptop to the board.
    Any help is appreciated.
  2. Craig K. wrote
    snip
    Bass will be along directly, after all, it's not rocket science.
    Right?
    js
