D
dep_blueman
Can I set a standard gel-cell lead acid battery on its end in an alarm
panel without issue?
The panel that holds our cellular backup hardware only has enough room
for 1 4 amp hour battery but will 'accept' per the docs. a 7 amp hour
battery. However, the only way to install the larger battery would be
to set it on end.
Not knowing much about these batteries I thought I would check here to
see if that is OK or not.
Thanks. D
to set it on end.
Thanks. D
