Gear Motor Source?
Discussion in 'Electronic Design' started by CCE, May 1, 2007.
  1. CCE
    CCE Guest
    I'm looking for a 12vdc gear motor with little luck. Here is what I
    need:
    12 vdc
    300-400 rpm
    10+ in-lb torque
    ~1/2 in shaft dia
    I have a car window motor, but it only runs at 160 rpm and that is too
    slow. This is a hobby project so I am price sensitive. Any
    suggestions?
  2. Tim Wescott
    Tim Wescott Guest
    Herbach and Rademan have a big selection and may have what you want.
    All Electronics also have a good selection, but H & R carries a better
    selection of bigger motors.
    Do a web search for "surplus" and "motor" -- you should get lots of hits.
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Posting from Google? See http://cfaj.freeshell.org/google/
    Do you need to implement control loops in software?
    "Applied Control Theory for Embedded Systems" gives you just what it says.
    See details at http://www.wescottdesign.com/actfes/actfes.html
  3. A good source for motors is www.herbach.com, but a quick search did not
    come up with the specs you seek. There are plenty of 115 VAC gearmotors for
    cheap, and you could use a small inverter to get the power from 12 VDC.
    Otherwise, you might be able to use a stepper motor with a drive circuit,
    or possibly mix and match gearheads and motors to get what you want.
    Another possibility is a small starter motor from an old lawn tractor. My
    1965 Simplicity has a 12 VDC starter that is also used as a generator. Your
    local junkyard may be a goldmine.
    Another online source is www.mpja.com. They have a 400 RPM gearmotor but it
    is 24 VDC: http://www.mpja.com/productprint.asp?product=17047+MD.
    Paul
  4. jasen
    jasen Guest
    cordless drill?
    Bye.
    Jasen
