GE CTC185 Chassis Horizontal lines
Discussion in 'Electronic Repair' started by Mr.Tobor, Sep 18, 2007.
  1. Mr.Tobor
    Mr.Tobor Guest
    Black horiz. lines about halfway down then more at bottom with some vertical
    foldback.
    Could it be a cap somewhere in the vert. output section? Thanks.
    MrTobor
  2. Art
    Art Guest
    Could also be lousy connections at the ourput device, the output device
    failing, or failing caps in the supply circuit that powers the vertical
    deflection output device. Confirm you have proper voltages at the output ic
    and at the supply.
