Gateway Solo 2550 Battery Module, How Do you open it?
Discussion in 'Electronic Repair' started by ClayC, May 26, 2006.
  1. ClayC
    ClayC Guest
    I have a Battery that is dead and with the price of a new one I want to
    see about rebuilding it.
    I do not see any external screws to open it. and if I do open it any
    recommendations on what cells I should be looking for to repace it. The
    Spec are at the following link.
    http://support.gateway.com/s/Mobile/peripher/6500332/650033203.shtml
    Please Help
    Clay
  2. bloggybob
    bloggybob Guest
    it is glued together and takes some careful measures to get it apart but im
    gonna tell you that your going to spend more money on batteries than you
    would just buying a new one .. also sometimes the charging board inside the
    battery pack goes belly up as well and then your back at square one .. so it
    is not feasable and cost efficient to even try to fix it ... buy a new one
    regards .. Bobs Laptop Repair
