Garage door opener
Discussion in 'Datasheets, Manuals and Component Identification' started by trainman9111, Mar 10, 2013.
  1. trainman9111
    trainman9111
    6
    Mar 10, 2013
    I am needing to know what this white tube's actual name is. I believe it is a frequency adjuster.
  2. davenn
    davenn Moderator
    13,948
    1,990
    hi there
    welcome to the forums
    The white tube is just a bit of plastic tube that supports the coilv (inductor)
  3. trainman9111
    trainman9111
    6
    Mar 10, 2013
    Excellent, Thank you for letting me know what this is so I can use a crystal for the 390 MHz mine took a dump, and I am too tight to buy one so I was going to make my own.
  4. davenn
    davenn Moderator
    13,948
    1,990
    I dont see a crystal on that board
    are there any other components on the under side ?
    if not ... it may just be a free running oscillator
  5. trainman9111
    trainman9111
    6
    Mar 10, 2013
    There is nothing on the bottom of the board just solder connections.
  6. trainman9111
    trainman9111
    6
    Mar 10, 2013
    I added a picture, to help in deciding what it is.
  7. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    The chip is a early solid state rolling code remote Tx module, the coil is there to fine tune the frequency...
    What are you trying to do?
  8. trainman9111
    trainman9111
    6
    Mar 10, 2013
    My other one broke and I was wanting to make my own, they cost 30.00, cheaper to make. Unless you know of a good website to make my own garage door opener.
  9. davenn
    davenn Moderator
    13,948
    1,990
    yeah ok
    the coil is slug tuned
    the problem is .... you have no idea if this remote TX is on the same freq as your existing one. There's every chance that they are very different
  10. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    That remote is a rolling code, it's paired to the receiver unless you system is using the same chips it's not going to work, and if it is using the same chips you would not need to modify it...
    As for remote cost, I have no idea of your brand or model number of your garage door system (FYI they are NOT all the same) but you can get universal remotes for pretty cheap just match it up to your system, they are well bellow $30 all over Ebay or even Amazon.com
    It's an old school remote, try contacting some garage door installers in your area they might have a drawer full of used ones that were reclaimed from swap outs...
  11. trainman9111
    trainman9111
    6
    Mar 10, 2013
    Ok Thank you. I appreciate all the feed back. I will end up buying one sounds like that would be the easier of everything.
Similar Threads
Loading...
