Garage Door Opener Leak?
Discussion in 'Troubleshooting and Repair' started by tricia, Feb 10, 2017.
  1. tricia
    tricia
    7
    Feb 10, 2017
    I have a Genie Max Pro. It hums but nothing happens. The motor doesn't turn. I see no leak from capacitor but a lot of orange sticky goo on circuit board. I need helping finding my problem so I can order/replace the right part.
  2. davenn
    davenn Moderator
    13,866
    1,958
    you have only shown a tiny part of the board ... show ALL the board viewed from above and also show the track side
  3. tricia
    tricia
    7
    Feb 10, 2017
    Here are more pictures. Any help appreciated.
  4. tricia
    tricia
    7
    Feb 10, 2017
    I disengaged the chain and it didn't turn. I also didn't see anything turning inside the casing. It just hums for about two seconds and stops.
  5. Minder
    Minder
    3,103
    664
    Apr 24, 2015
    Are you sure it is not mechanical, is the motor trying to turn?
    Either the motor could be jammed or the start/run capacitor for the motor is the object leaking.
    If so the motor will just hum.
    M.
  6. tricia
    tricia
    7
    Feb 10, 2017
    I don't see a leak on the capacitor but orange goo on the board and wires. Is that normal? If so I will replace the capacitor and hope that fixes it.
  7. Minder
    Minder
    3,103
    664
    Apr 24, 2015
    Do you see the motor trying to turn?
    If so It is usually two things, either the cap is bad or if it is the style that has a plastic worm & pinion, the gear wears and jams.
    The run cap is not usually on the board but mounted close to the motor.
    M.
  8. tricia
    tricia
    7
    Feb 10, 2017
    Thank you. I will replace the capacitor tonight and see.
  9. tricia
    tricia
    7
    Feb 10, 2017
    Is there any cautions I should take?
  10. Minder
    Minder
    3,103
    664
    Apr 24, 2015
    The cap for start/run should be a an AC rated run motor capacitor.
    If you can remove the motor from the drive you can test to see if it runs when no load.
    M.
  11. tricia
    tricia
    7
    Feb 10, 2017
    I don't understand. Sounds Chinese to me.
  12. Minder
    Minder
    3,103
    664
    Apr 24, 2015
    Here is a picture to make it easy!!
    Pull the motor off the mounting and see if it runs and is free to turn.
    M.
