Jon Slaughter
Is it common to parallel h-bridges?
Jon Slaughter said:Is it common to parallel h-bridges?
BTW, I can't seem to find any in-expensive H-Bridges for 180W@12V so I was
thinking of using two of these
http://www.fairchildsemi.com/ds/FD/FDD8424H.pdf
Terry Given said:sounds like a recipe for disaster at currents below 30A. But its also why
IGBTs can be direct paralleled (nice +ve tempco). Extremely tight thermal
coupling can get around a lot of the problems though.
the easiest way to parallel H-bridges is with interphase reactors to soak
up all the little variations. Depending on the load, split the first
inductor into N inductors for N bridges, each N times more henries and
1/Nth the current so each one is N*(1/N)^2 = N times smaller. join the
ends of the inductors together, then continue with the rest of your
circuit.
I don't see any difference between parallel H-bridges and discretizing the
H-bridge and paralleling the individual mosfets... which is no problem.
If you don't think it is a problem, you haven't been doing it for long
enough or on a large enough scale.
If you want to parallel MOSFETs or discrete transistors you almost
always have to add components to make sure that each active device
carries more or less the same current. Production tolerance is not
your friend.
But this contradicts AOE and many other sources I have read that say
paralleling them is no problem. MOSFETS have negative temperature
coefficients rather than positive like BJT's. (hence as one gets hotter it
gets more resistive and less current will flow through it and through the
other.. they should ultimately balance out, in proportion, if it is not too
bad)
I assume then you mean that one mosfet might take a little more current than
another because they are not exactly the same. Ok, that might be true but
then you just add one more mosfet to the mix and it should compensate enough
(assuming they are not that much different, which I imagine they aren't).
The only issue it says is that the more you parallelize the more gate cap
you have hence its harder to drive(and eventually becomes impossible).
Of course that stuff is for discrete mosfets and I'm not sure about
h-bridges(specially since they probably have more circuitry in it for other
things, in general).
essentially you are both right.
The trick is to keep them in very close
proximity, with extremely tight thermal coupling. And dont forget to use
one Rg per FET. Symmetry is your ally here; visual disharmony is the enemy..
too
bad)
than
enough
other
for example,
"Differential RDS (on) will cause current unbalance and extra conduction
losses as expected, but these are limited due to the
positive temperature coefficient for MOSFET resistance. The thermal
'runaway' characteristic of other semiconductor technologies
does not apply to MOSFETs."
"Gain factor differentials (DGF) result in limited current unbalance. In the
extreme, which is difficult to realize in practice,
the current unbalance is limited to the gain ratio. Since turn-on
differentials are very easy to control, the predominate loss
differential occurs during turn-off."
And the pdf just about contradicts everything you have said so far. (except
maybe in the rare case where there is a complete parameter mismatch). Of
course its not only the pdf but other sources too.
I suspect Bill is thinking about linear applications.
I have no idea but I have read about 10 sources, one such as AOE, that says
they can easily be paralleled and say nothing else about "issues" that bill
is talking about. Of course if you just take two random mosfets(such as a
power and a small signal) and throw them together then it probably won't
work... but that pdf says in general there are no issues and only when the
parameters are significantly mismatched will there be an issue.
My guess is he really think's MOSFET's are BJT's cause everything he is
talking about pretty much applies to BJT's but not MOSFET's.
Go back to my original response (the third one in the list) and read
it to the end. Then take a careful look at the datasheet that you
posted. MOSFETs only had a positive temperature coefficient for high
drain currents - higher than you are likely to be using. Check out the
drain current versus gate-voltage curves in the data sheet you posted,
rather relying on Win Hill's thirty year-old observation about a much
smaller MOSFET than you will be using - the 2N4351 data in his figure
3.13 switches to a positive temperature coefficient at 2mA, which the
Fairchild part you are contemplating has a negative temperature
coefficient up to 30A.
And MOSFETs have fairly large gate threshold voltage tolerances, so
you are quite likely to start off with all the current going through
one of your parallelled MOSFETs, which isn't a good start.
Using your imagination is a poor substitute for reading the data sheet
carefully
It never becomes impossible - the switching times just grow in direct
poroportion to the number of MOSFET's.
Dream on. If they do incorporate current limiting or thermal
protection, the data sheet will tell you about it, and you won't want
either to come into action in normal operation.
I suggest you read
http://www.irf.com/technical-info/appnotes/para.pdf
because you seem to think MOSFETS = BJT's
Terry Given said:I suspect Bill is thinking about linear applications.
