gain bandwidth product / op amps
Discussion in 'General Electronics Discussion' started by komalbarun, Aug 25, 2013.
  1. komalbarun
    komalbarun
    67
    Nov 25, 2011
    Hi all,
    1.How do we calculate gain-bandwidth product of an op-amp?
    like if :
    i have open loop gain Ao = 100,000.
    Bandwidth = unknown .
    Ao x unknown = ??
    2.what does frequency response, badwidth mean? how do these affect the output?
    3. What do we mean when we talk about unity gain in op-amps. Does it mean that gain=1?
  2. BobK
    7,682
    1,688
    1. You don't, you get it from the datasheet.
    2. GBP is the product of the gain and the frequency. Say it is 1 MHz. That means you will have unity gain at 1MHz, gain of 10 at 100KHz, gain of 100 at 10KHz etc.
    3. Yes.
  3. komalbarun
    komalbarun
    67
    Nov 25, 2011
    thnx a lot Bobk.
    There's still something i want to understant.
    cut off frequency = the frequency below which and above which output will not be as expected? that's how it seems to be after a lot of online reading xD.
    but, how do we get the -3dB?
    10 log 2 = 3 <--ok, i got it.
    10
    but:
    where does the 2 come from Oo?
  4. (*steve*)
    25,490
    2,831
    The 2 comes from a factor of two -- a doubling or halving (in your case you are actually looking for 10 log 0.5).
    The the Log (base 10) part comes from the definition of a Bel and the fact that it's logarithmic and specifically log base 10.
    The 10 part comes from the fact that you want dB, not B.
  5. komalbarun
    komalbarun
    67
    Nov 25, 2011
    Thx to both of you, things are much clearer now ^__^
  6. eman12
    eman12
    31
    Aug 24, 2013
    Hi komalbarun,
    If I was you, I would try to take a look at the datasheet of "LM3886" Op-amp. It talks about GBP and give you an good example in this regard.
