From the PDF page 34...
When measuring direct voltage up to 400 volts the unknown voltage is applied to TL5. It is fed via contact 3 or 5 (don't they know then? -sinewave) and the rotor of SB3 (according to polarity), the rotor and contact 10 of SC1 and the rotor of SA8 to the appropriate point along the series resistor chain R19-R23, R37-R40, R117-R121, R114, R115 and R131. The output from the resistor chain is applied directly to the input of the chopper circuit. When making measurments with the 40v, 120v and 400v ranges, voltage divider resistors R16-18 are bought into circuit by SA14. These resistors in conjunction with capacitor C20, also for the low-pass filter which minimizes any superimposed alternating voltage. On the 1200v range, the unknown voltage is applied to terminal TL3 which is connected to the chopper circuit via R154, R155, R156 and R15.
So, SC being the measuring finction range, SA being the range value and SB being the main on/off/+/- switch.
From what I can gather the numbers suffixing 'SC' on the drawings related to the wafers, with 1 being close to the front of the meter, with the numbers climbing the further to the rear of the meter the wafers go.
I'm going to see what I can spot, considering this oscillation happens only on DC, current or voltage.
