Futurenet to PADS conversion
P
Paul E. Schoen
I have quite a few older schematics in Futurenet 6.10, and although I can
still run the old program to edit the files, I would rather recreate them in
a more modern format. I have PADS PowerLogic and PADS Logic 2004SP2, and
would like to convert the files so I can use the newer schematic editor and
possibly use some of the specialized component library in new designs.
I have found many netlist converters, but most of my schematics are for
electrical designs which are not for PCBs. I have started a Delphi project
to convert the Futurenet binary files to PADS Version 4 ASCII files. I have
been fairly successful, but so far I can only show connections as individual
drafting lines, and the components do not have their internal graphics.
If anyone has information on the Futurenet file format, I would greatly
appreciate it. I have figured out much of it by experimentation, but that is
definitely a hard way to go.
If you'd like to see how my program works (so far), you can download it at:
www.smart.net/~pstech/FN2PADS.
I would like to know if anyone finds this helpful.
Once I have the format figured out, it should be possible to convert to
other schematic tools you may be using, if I have the ASCII file format.
