fuse question
Discussion in 'Photovoltaics' started by Don Miller, Jun 2, 2004.
  1. Don Miller
    Don Miller Guest
    I've got two 12 volt Shell 110 watt panels that I'm going to be wiring to
    produce 24 volts to system. I plan on ultimately having a total of 10
    panels when money allows.
    I have a Trace combiner box that has 250 volt, 20 amp fuses. I think they
    might be too big.
    Once merged to make 24 volts, I "think" that I should use a 10 amp fuse on
    each pair of panels at the panel combiner box before the run to the charge
    controller / etc.
    I am about to order some 10 amp, 250 volt fuses. Right?
    Don Miller
