Fuse or fusible resistor?
Discussion in 'Electronic Components' started by DaveC, Jun 27, 2010.
  1. DaveC
    DaveC Guest
    Used in the battery (-) lead of a handheld scope. Schematics unpublished.
    Physically similar to a 1/4 W resistor, color light green. Marked "IE7A" or
    "1E7A".
    Google returns slim results, none promising.
    What type is this?
  2. A grammar nanny, eh?
    You must be a big hit at parties ...
  3. Pieyed Piper
    Pieyed Piper Guest
    Jeez. Yer an idiot.
  4. Pieyed Piper
    Pieyed Piper Guest
    I should have figured that not a goddamned soul actually tried to answer
    the question.
    It sounds like a 'soft-fuze'. That resets itself after tripping.
    There is also a similar device used in hair dryer circuitry.
  5. Phil Allison
    Phil Allison Guest
    "DaveC" <
    ** Sounds like a Pico Fuse:
    http://media.digikey.com/photos/Littelfuse Photos/PICO II R251 SERIES.jpg
    Come in fast and very fast ratings with amps rated from 1A to about 15A.
    When they blow, you need a soldering iron to replace them.
    There are various Asians clones too.
    ...... Phil
  6. Phil Allison
    Phil Allison Guest
    "DaveC"
    ** Sure that is not the other way around ?
    Pico Fuse would use " 7A LE " as a the marking for a 7 amp fuse.
    ..... Phil
  7. N_Cook
    N_Cook Guest
    I take it , that its blown and I also take it that its not charred (fusible
    R don't char or even discolour AFAIK)
    Desolder it and scrape an axial line along its length . Then DVM resistance
    check from either end. If a fusible resistor then maximum R read is what its
    value was near enough.
    FR breaks are usually to one end, normal R usually in the middle.
    Although green is often axial inductor.
  8. Littlefuse makes green resistor-shaped fuses. Their logo is an 'L'
    wrapped under an 'F' so their 'LF' could look like 'IE' on a worn part.
    http://www.littelfuse.com/data/en/Data_Sheets/Littelfuse_251_253.pdf
  9. DaveC
    DaveC Guest
    Thanks, Kevin.
    They way Littelfuse uses a stylized "LF", it could easily be mistaken for
    "1E" or "lE".
    Now to get one...
    Thanks again,
  10. DaveC
    DaveC Guest
    No, I don't have one. I threw it out with the old battery. :-(
    Someone on-line volunteered to describe the one from his scope.
    I'll not ask him to do a post-mortem on a working fuse. ;-)
  11. Pieyed Piper
    Pieyed Piper Guest
    The axial leaded jobs I have seen in hair dryers are high current jobs
    with reed switches inside them. Not the soft break jobs.
    The biggest soft device I recall was 3 Amps.
  12. Pieyed Piper
    Pieyed Piper Guest
    If you cannot glean the question from that, you are not only too
    goddamned retarded to be answering it, you are too goddamned retarded to
    be in the group at all, much less being here, acting like you have half a
    fucking brain.
    Nice sig, dumbfuck. It fits you perfectly.
  13. Ratings of these beasts in equipment is almost NEVER disclosed - like
    And that's why markings are so important. You can circumvent any need to
    measure.
  14. Arfa Daily
    Arfa Daily Guest
    They are complete s
    Just not ones that you
    What I am writing, are incomplete sen
    And don't
    We don't like that on sci
    Arf
  15. Tim Williams
    Tim Williams Guest
    Obviously, it's 10,000,000 amperes ;^)
    Tim
  16. Jamie
    Jamie Guest
    good one :)
  17. James Sweet
    James Sweet Guest
    They won't catch fire but I have seen them char slightly. It's also
    common for them to crack or blow out a small chip of ceramic if
    something shorts and exposes them directly to the line voltage.
