Anyone recommend a low price function generator? JERD
D David L. Jones Jan 1, 1970 0 Aug 25, 2009 #2 JERD said: Anyone recommend a low price function generator? Click to expand... Define "low price". What specs? The are 2-5MHz asian no-name jobs going for under $200 on Ebay. Used is also an option for name brand stuff. Dave.
P Phil Allison Jan 1, 1970 0 Aug 25, 2009 #3 "JERD" Anyone recommend a low price function generator? Click to expand... ** This kit will do as a basic function generator - for $27.50 http://www.altronics.com.au/index.asp?area=item&id=K2544 Just depends what "functions" you expert. Shame you are too stoopid to post any. ...... Phil
J JERD Jan 1, 1970 0 Aug 25, 2009 #4 Phil Allison said: "JERD" ** This kit will do as a basic function generator - for $27.50 http://www.altronics.com.au/index.asp?area=item&id=K2544 Just depends what "functions" you expert. Click to expand... Sorry guys, Approx 0.1 Hz to 2 Mhz Sine, square, pulse are the main requirements. JERD
D David L. Jones Jan 1, 1970 0 Aug 25, 2009 #5 JERD said: Sorry guys, Approx 0.1 Hz to 2 Mhz Click to expand... Here is a cheapy ebay one: http://cgi.ebay.com.au/Digital-Func...ment?hash=item3ef7e2bd5c&_trksid=p3286.c0.m14 Sine, square, pulse are the main requirements. Click to expand... You usually won't get pulse generation in a standard function generator, you need, well, a pulse generator for that. Dave.
P Phil Allison Jan 1, 1970 0 Aug 25, 2009 #6 "David L. Jones" You usually won't get pulse generation in a standard function generator, you need, well, a pulse generator for that. Click to expand... ** The "pulse" function often just means there is a knob that varies the duty cycle of the square function over a wide range ( like 1% to 99% ) with zero or variable voltage reference. ...... Phil
