fully differential opamp implementation
Discussion in 'Electronic Design' started by tiger66, Mar 10, 2007.
  1. tiger66
    tiger66 Guest
    Hi All
    I need a fully differential opamp for my circuit design.
    Unfortunately, the simulator I use, multisim, does not have a build in
    fully differential opamp.
    So, I was wondering if any of you have experience implementing a fully
    differential opamp, can you please help me to implement one?
    Any resources (i.e. netlist, circuit diagram) will be really
    appreciated
    thanks
  2. John  Larkin
    John Larkin Guest
    google "three opamp differential amplifier". Or cheat and use a Spice
    vcvs, which is a perfect diffamp.
    John
  3. Fred Bartoli
    Fred Bartoli Guest
    John Larkin a écrit :
    But the output is not diff.
    But the output isn't referenced WRT to common mode. You'll have to use 2
    VCVS for this, or 3 if you don't want to reflect the output current to
    the CM ref input.
  4. Jim Thompson
    Jim Thompson Guest
    I'll knock one out for you for $25K, payable upfront ;-)
    ...Jim Thompson
  5. tiger66
    tiger66 Guest
    Thanks very much John for the response.
    I was designing my fully differential opamp using "three opamp
    differential amplifier" concept initially because it only requires two
    basic opamps and 4 resistors which my simulator has all the
    components.
    Unfortunately, after I connect the input of the three opamp
    differential amplifier to the output of my modulator, I get "timestep
    too small" error message when simulate. Do you know how to debug this
    problem?
    Currently, my circuit can simulate fine using vcvs as you suggested.
    Do you know if there are any disadvantage for using vcvs instead of
    normal fully differential opamp? Would it affect my output signal
    spectral analysis significantly?
    Thanks again for your assistant
  6. tiger66
    tiger66 Guest
    Hi Fred
    Are you talking about "common mode feedback circuit"?
    I was reading about that when I was researching about fully
    differential opamp. Unfortunately, I can't find a detailed explanation
    about the CMFC(i.e. the articles only show the schematics but not the
    values I should use for MOSFET, capacitor, resistor and reference
    voltage). So I really don't know how to integrate CMFC with opamp.
    Do you have experience implementing the fully differential opamp? Can
    you send me a netlist of that, so I know what values to put for each
    components
  7. tiger66
    tiger66 Guest
    Thanks for the offer Jim, but I am a poor engineering student. So I
    can't afford that kind of money
    But I think I can offer you $1 if you can help me design a fully
    differental opamp. $2 if you can help me design a chopper stabilized
    amplifier
  8. Jim Thompson
    Jim Thompson Guest
    "Perfect" VCVS has no delay or phase shift, infinite bandwidth... all
    of the constituents of instability.
    Back up and study how to model an OpAmp, with at least one pole.
    ...Jim Thompson
  9. Eeyore
    Eeyore Guest
    I suspect you don't mean 'op-amp' you probably mean differential amplifier.
    Graham
  10. John  Larkin
    John Larkin Guest
    Is that what he meant by "fully differential"?
    Whatever.
    John
  11. John  Larkin
    John Larkin Guest
    If you are trying to evaluate the spectral properties of a diff-output
    mixer, the vcvs is literally ideal. An opamp thing will just add its
    own complications and abberations.
    If you eventually want to build the circuit, you will need a diffamp,
    I suppose. Or a transformer. There are some nice, integrated, very
    fast diffamps around these days.
    John
  12. Hi,
    If he search the spice models he should look by the factories...
    http://www.ti.com/litv/zip/sloj158
    may be a good start.
    Marte
  13. tiger66
    tiger66 Guest
    Thanks, I guess I need to learn how to use Pspice now.
    Can Pspice generate the Power Spectral Density of a signal? I need to
    do some spectral analysis in my circuit
  14. Ban
    Ban Guest
    With the 3 opamp IA circuit you can just add an identical output
    differential amp stage with the inputs inverted to obtain the other output
    signal.
  15. Jim Thompson
    Jim Thompson Guest
    Yes. You can do a spectral analysis in Probe, or can define
    distortion analysis in the setups to get a table.
    ...Jim Thompson
  16. Hi tiger,
    You do not need to switch the program. Multisim can use (p)Spice models as
    well as LTSpice for example. The changes that may have to be made are very
    little and almost known in the support forums.
    Marte
    .... who prefers to use LTSpice
  17. vasile
    vasile Guest
    Even it can, and even if you do it right on simulation, on the real
    world will be different
    (could be very different at high frequencies)
    Focus on fully differential OA datasheet available at Analog Devices,
    Texas Instruments and Linear Technology.
    There are a lot of articles about those. Some clues: AD8132, THS4121,
    LT1994
  18. John  Larkin
    John Larkin Guest
    The cold end of the resistor going into the + input of the 3rd amp is
    the output reference; it need not be ground.
    John
  19. tiger66
    tiger66 Guest
    Hi All
    Does anyone have experience using multisim?
    I keeps getting a "timestep too small" error message when I simulate.
    I tried all the debugging method I found online, but non of them
    solves my problem
    Any input/assistant on this would be really appreciated
    thanks
  20. Eeyore
    Eeyore Guest
    I told you before.
    It's crap.
    Graham
