Fujitsu Plazma TV.
Discussion in 'Electronic Repair' started by Dani, Apr 20, 2007.
  1. Dani
    Dani Guest
    Fujitsu Model # PDS4209U-B, unit comes on, & switches inputs, has a
    raster, & OSD, but has no video, with VGA input it has a very washed
    out pix, & can barely be read. I have all the voltages to the in/out
    video card. Can't locate service info, or tech support around here.
    Anyone see this type of fault with this model? Thanks, Dani.
  2. Meat Plow
    Meat Plow Guest
    Nope.
    #1 Offishul Ruiner of Usenet, March 2007
    #1 Usenet Asshole, March 2007
    #1 Bartlo Pset, March 13-24 2007
    #10 Most hated Usenetizen of all time
    Pierre Salinger Memorial Hook, Line & Sinker, June 2004
    COOSN-266-06-25794
  3. Jerry G.
    Jerry G. Guest
    These monitors are serviced only at the board level. There is no factory
    support to service these monitors at the component level. Start by
    trying out the main video input processor board, and then work through
    the monitor by trying the others along the process path.
    Unfortunately, because you are not an authorized service rep, you will
    have to purchase the boards to try them. It would be more feasible for
    you to send the monitor to their factory service rep to have it
    serviced. If the unit is more than 3 years or out of warranty, it may be
    a better option to replace the set.
    Jerry G.
