K
Ken S. Tucker
I had two of them ('85 and '90). Both sucked. Neither made it to 100Kmi.
We're at 120Kmi on a 2005 job, so far so good.
We pulled all passenger seating so wife uses it as a delivery vehicle.
Ken
Martin said:Penniless racist trailer trash like Tucker couldn't afford it.
I thought these days that they had largely solved that problem. US cars
are just too heavy, with sloppy suspension, gross understeer and slow to
be interesting.
That is until you put >6L engines in them.
My next computer desk will have a 'computer floor' on top of the desk
to hide & route all of the cables. The top will lift off in various
sized pieces to access the wiring area. Hollow posts on each side to
hold a printer shelf above the mointors, and hide the wires.
Bill said:Phased-array ultrasound scanners, electron micrscopes. electron beam
microfabricators, stroboscopic electron beam testers, The Affinity
Sensors "resonant mirror" protein-sensing system ... it's a long list.
Developing complex systems involves a lot of trouble-shooting, as you'd
know if you'd ever done it. At Cambridge Instruments I occasionally also
got dragged in to help with knotty problems on other projects, or stuff
that had come up in production.
be interesting. That is until you put >6L engines in them.
josephkk said:Just did a search looking for over 300 hp cars, check out the Buick
Lacross and some Cadillacs; biggest engine 3.6 L V6 and over 300 hp on a
3.0 L V6. Your turn.
So, you know nothing of the design, yet you know it can't work. No
surprise. Your comprehension sucks, as usual. I said, 'VARIOUS SIZED
PIECES' which you seem to think the entire surface will be in tiny
pieces. It means that the areas that need wires run will lift out as
needed. Extra pieces will have the cutouts so you can arrange the back
half in any way you desire. You know, the computers, monitors & all the
loose items with wires. That will leave about 2/3 of the top as one
solid piece for a keyboard, mouse or other work area.
Some people have no vision, even if they were given detailed plans.
So -- buy a camera with a decent name behind it, that's not the cheapest
one out there for its features, and cross your fingers.
Not when the desk has to sit against a wall. You can do everything
from the top, without dragging hundreds of pounds of desk & other
equipment out to make changes.
You didn't ask, you just attacked. Actually, it will be over 60"
wide. That's one reason I need a new desk. Things are hanging off all
edges of this 36"*60" inch desk.
Why should I? You aren't going to build one.
Attacked? I know you're in pain, Michael, but you need to get your head out
of your ass.
I didn't know there was training for trouble shooting? I thought itKen said:So you have never been trained in trouble-shooting, just did by-gosh, by
golly. That's a BIG hole in your education, couldn't make technician.
Ken
In that area, I'm an autodidact,
like pretty much everybody else I've
ever worked with. I'm not the best trouble-shooter I know - that was
Mike Penberth, who never lost track of which hypotheses were supported
by the evidence we had
http://www.justgiving.com/Mike-Penberth
but I was as good as or better than everybody else I worked with, and
popular with the technicians, who called on me in when they were
stuck.
As usual, your imagination is telling you stuff that isn't actually
true, and you are too dim to realise that this is going to be obvious.
Jamie said:I didn't know there was training for trouble shooting? I thought it was
training to learn how things worked and the trouble shooting should
follow naturally?
If that fails, then you're in the wrong business.
Pulling a whole section of electrons just because some major test point
that means nothing to you, failed the test procedure is a very costly
way of doing business.
But, if there is such a thing, then the detection of blue smoke
escaping its nest must be one of the items that a training course would
teach you as an indication that sum-ting is wong! Something that maybe
you are more familiar with.
Jamie
