FRONT END WITH PLL
Discussion in 'Electronic Design' started by RealInfo, Feb 3, 2009.
  1. RealInfo
    RealInfo Guest
    Hi all
    In a PLL contrlolled Rf amplifier front end how exactly the 1st RF stage
    frequency of the tuned circuit is contrlolled so it
    will be exactly the PLL freq+ IF frequncy ?
    EC
  2. One method that gets used is lots of switched caps with varicap
    fine tuning. But all-band radios are inevitably a compromise.
    The key thing is to be exceptionally linear and low-noise across
    a large dynamic range, so intermodulation doesn't become an
    issue before you hit those IF filters, or you get all kinds of
    spurious out-of-band response. The new DTV chipsets are amazing.
  3. MooseFET
    MooseFET Guest
    The tuned circuit has a wide enough band width that a simple circuit
    with varactor diodes will be close enough.
    The VCO tuning can also be a varactor diode. With care the voltage to
    frequency character of the two can be matched.
  4. TheM
    TheM Guest
    Sounds interesting
    What are the specs, model numbers?
    M
  5. Anadigics is one maker, look at their AIT-1010 and AIT-1021.
  6. Jamie
    Jamie Guest
    look up "RF mixer.."
    http://webpages.charter.net/jamie_5"
  7. RealInfo
    RealInfo Guest
