from 5V battery to AC circuit with good frequency
Discussion in 'Power Electronics' started by Federico, May 7, 2015.
  1. Federico
    Federico
    3
    May 7, 2015
    Hi guys! Can you help me? I want to build a AC circuit starting by battery!
  2. cl10Greg
    cl10Greg
    25
    3
    Mar 20, 2014
    You can search DC/AC inverter and it should give you some examples. You can do a modified sine wave (which can't run heavy loads or all AC loads) which uses a bridge a transistors to mimic a sine waves or there are some other options that will involve an oscillator and transformer to produce the AC waveform. Keep in mind what the power requirements are such as the voltage, current draw, etc... as well as an protection circuits.
    Federico likes this.
  3. Federico
    Federico
    3
    May 7, 2015
    Thanks! I don't want to use inverter and i can't use an oscillator but I must build a circuit that does it!
    So, have you a picture that explains the circuit?
  4. (*steve*)
    25,500
    2,840
    Your question is very non-specific.
    The generic answer would be for you to google "oscillator schematic", however if you can tell us what you want to do with this we may be able to give more specific help.
  5. davenn
    davenn Moderator
    13,901
    1,971
    you have to use an oscillator, its the only way to get AC from DC
    Do you understand that a AC signal/voltage is an oscillating one ? ..... seems like you don't
  6. Federico
    Federico
    3
    May 7, 2015
    I want build an oscillator starting by battery... ;-)
  7. (*steve*)
    25,500
    2,840
    Google "oscillator schematic"
  8. BobK
    7,682
    1,688
    What frequency? What waveform? What voltage? What current?
    davenn likes this.
