S
Simon Morden
I'm trying to remember my limited 20-year old electronics knowledge and
failing miserably...
Some background: the school I work at is involved in a science
competition run by Rolls Royce. Our project is to make a wind tunnel and
test turbine designs. I am in charge of the instrumentation.
The problem: I need to be able to record the rpm of the test pieces.
What I've done so far: I have availed myself of the National
Semiconductors' LM2917 (14-pin), as detailed here:
http://www.national.com/mpf/LM/LM2917.html
It's a dedicated frequency to voltage IC, and I'm running it off a 9v
battery. I've set it up so that it works - I can input an ac voltage and
get a proportional dc output.
What I can't do: I can't make my rpm detector talk to the chip. The
detector set up is a bike computer sensor and a 3v battery. Output is
pulsed dc which does not fall below ground - and the chip requires that
pin 1 goes at least -30mV on each cycle.
What I can't do (part2): I know I have to use something like capacitor
coupling to strip out the dc and keep the ac. I know I have to keep RC<T
because I'm trying to just get the voltage spikes +/-. What I really
can't do is make what on the face of it should be a really simple
circuit to convert the pulsed dc train (at 10-100 Hz) into a pseudo ac
voltage with a large enough variation to fool the chip.
Any help gratefully received!
Simon
Simon
