frequency generator and phase detector
Discussion in 'General Electronics Discussion' started by saurabh17g, Mar 29, 2010.
  1. saurabh17g
    saurabh17g
    72
    Mar 8, 2010
    I want to build a circuit which generates a frequency from 1Hz to 20 MHz.
    After generating the frequency, i m passing it thru a material and the material changes the phase of the incomming wave. I want to get the phase difference of the input wave and output wave (got from the material).
    Is there any ic which has frequency generator and phase detector?
  2. (*steve*)
    25,499
    2,839
    That's an extremely wide range of frequencies.
    What sort of output do you require? Does it have to be a sine wave, or will a square wave be ok? What output voltage? What output impedance? What is this external substance and how will the signal be detected?
  3. saurabh17g
    saurabh17g
    72
    Mar 8, 2010
    output:
    the reading of phase diff should be displayed.
    It has to be a sinewave.
    voltage (input) 5V normal.
    substance is a sensor.
    i m also thinking about how to detect the signal.
