Frequency divider and multiplier
Discussion in 'General Electronics Discussion' started by arg733, Sep 7, 2012.
  1. arg733
    arg733
    89
    Dec 14, 2010
    Hi I was wandering if there is a way of dividing and/or multiplying frequencies by 100 or even 1000?
    I couldn't find anything on google in that range.
    As i don't have a pic programmer i cant make something with a pic (that i suspect would solve my problem)
    I need it to make my own frequency counter and frequency generator using picaxe
  2. (*steve*)
    25,480
    2,827
    If you're not concerned by the waveform, division can be done using a divider.
    You could also investigate PLLs.
    What do you need this for? There may be an easier solution.
  3. arg733
    arg733
    89
    Dec 14, 2010
    Thanks Steve, for division i don't need the waveform to be identical i only need it to give an accurate and steady number of pulses i don't care how much it alters the waveform and even the duty cycle.
    For the multiplier i need it to be as accurate as possible, maintaining waveform and duty (of course i am ok if it changes sine wave to square.)
    Edit: just looked for the PLLs seems fine for me (if you tell me how to wire it of course :) )
  4. Harald Kapp
    11,157
    2,548
    Here is an application sheet for the popular 4046 PLL.
