Frequency dependent resistor in PSpice
Discussion in 'General Electronics Discussion' started by Bala_01, May 31, 2016.
  1. Bala_01
    Bala_01
    6
    May 30, 2016
    Think a simple case. I want to create frequency dependent resistor R1. The value of R1 is as follows:
    at 1 MHz -> R1 = 2
    at 5 MHz -> R1 = 10
    at 10 MHz -> R1 = 20
    at 100 MHz -> R1 = 200
    Thant means R1 is a function of frequency where R1=2* Frequency. Consider only the numerical value of frequency not unit. How can I implement in Pspice ?
    Best regards,
    Bala
  2. davenn
    davenn Moderator
    13,810
    1,944
    pretty sure there's no such thing as a frequency dependent resistor
    in my 40+ yrs of electronics have never heard of one
    so what are really trying to achieve ??
  3. Bala_01
    Bala_01
    6
    May 30, 2016
    I have found the solution. It can be done with Laplace transformation.
    ************ Test ***************
    .subckt Test01
    + 1 2
    G_Rvar1 1 2 LAPLACE { V(1)} {1 /((1/K1)*(s/(2*PI)))}
    .param K1=1
    .param PI =3.141592654
    **********K1=1 when Frequency in Herz
    **********K1 =1e6 when Frequency in MHz
    .ends
    I need this info to test a HV Filter.
    Bala
  4. LvW
    LvW
    604
    146
    Apr 12, 2014
    Perhaps, this is not what the OP (Bala_01) needs - but there is a very versatile active circuit called "Frequency-Dependent Negative Resistor (FDNR) " consisting of two opamps. Such a device is extensively used in active filters and harmonic oscillators. It is a special version of the universal GIC circuit.
  5. Alec_t
    Alec_t
    2,949
    803
    Jul 7, 2015
    Can't you just right-click on the resistor value in the schematic and set the value to {2*frequency} ? Then add a directive .param frequency=3meg (or whatever).
    Bala_01 likes this.
  6. Bala_01
    Bala_01
    6
    May 30, 2016
    I need a Pspice netlist model which I can import in CST DS.
  7. CDRIVE
    4,960
    651
    May 8, 2012
    Ha, I know that this is not what you meant but attempting to use a wire-wound resistor as a 50Ω RF Dummy-Load comes close to fitting the definition. :D
    Chris
    Arouse1973 likes this.
