Frequency dependent current controlled voltage source in Pspice
Discussion in 'General Electronics Discussion' started by Bala_01, May 31, 2016.
  1. Bala_01
    Bala_01
    6
    May 30, 2016
    I need to create a frequency dependent current controlled voltage source in Pspice netlist. The netlist is the following:
    ************ Test ***************
    .subckt Test01
    + 1 2
    R1 1 11 5
    H11 11 2 V1 {R_CM}
    L1 1 12 5e-6
    V1 12 2 0
    ***Where R_CM = 2*Frequency
    **** Here Frequency is the simulation frequency
    *** only needs to consider numerical value of frequency not unit
    .ends
    How can I define this R_CM in Pspice ?
    Best regards,
    Bala
  2. Alec_t
    Alec_t
    3,050
    830
    Jul 7, 2015
    Don't know about Pspice, but for LTspice you could put a directive on the schematic, e.g. for a frequency of 60Hz the directive would be .param R_CM = 2*60.
    Bala_01 likes this.
  3. Bala_01
    Bala_01
    6
    May 30, 2016
    Hi Alec_t,
    I know how to implement it in LTSpice. But I need a PSpice netlist model. Later I want to import this pspice model in CST DS and use it in my simulation. Thanks for your reply.
  4. CDRIVE
    4,960
    652
    May 8, 2012
  5. eetech00
    eetech00
    95
    8
    Nov 17, 2014
    you should be able to use the subckt as is with the following modification:
    1. add a parameter statement, with a default value, right after the subckt statement:
    .subckt Test01 PARAMS: R_CM="a default value w/o quotes"
    Then place the part on the schematic and set the R_CM parameter on the part.
  6. Bala_01
    Bala_01
    6
    May 30, 2016
    Hi eetech00,
    Thanks for your reply. It will work if you run it in PSpice. But my aim is to use it in CST DS. There I can only import the spice netlist file. I can not write any pspice command in CST DS schematic. I have to write everything in pspice netlist. I do not know whether you have experience with CST.
  7. eetech00
    eetech00
    95
    8
    Nov 17, 2014
    No...haven't use CST but am very familiar with spice code and netlist.
