Frequency conversion from 400 Hz to 50/60 Hz
Discussion in 'General Electronics Discussion' started by AMIT SAXENA, Nov 21, 2015.
  1. AMIT SAXENA
    AMIT SAXENA
    Nov 21, 2015
    We need to use a particular device which is intended to use with 220-240V, 50/60 Hz, 16 A, now as an aircraft has has 400 Hz. supply. How we can use this device in aircraft. Also, the frequency converter manufacturing companies are very less specially for step down. please suggest.
  2. KMoffett
    KMoffett
    720
    73
    Jan 21, 2009
    hevans1944 likes this.
  3. Alec_t
    Alec_t
    2,902
    784
    Jul 7, 2015
    Welcome to EP!
    What is the 'particular device'?
    Can it be modified?
    Will it accept output from a 'modified sinewave' type inverter, or only from a 'pure sinwave' inverter?
    What is the aircraft supply voltage?
    hevans1944 and davenn like this.
  4. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    If it can be modified, can it be run on DC, rectified from the 400Hz supply?
  5. GPG
    GPG
    452
    66
    Sep 18, 2015
    A lot of power. What aircraft?
  6. (*steve*)
    25,418
    2,788
    I suspect the 16A is not the current drawn at 220V....
    Anything with a switchmode power supply is likely to be perfectly happy with 400Hz.
    Devices with transformers may also work.
    I have seen a large number of test instruments that are rated for various voltages at 50/60 Hz, and for a limited subset at 400Hz. If you've ever operated your laptop on board an aircraft then you've been operating it from a 400Hz supply (far more likely than not)
    Best thing is to ask the manufacturer since it's often more of an issue if something fails (especially if it fails with smoke and flames) in an aircraft.
  7. AMIT SAXENA
    AMIT SAXENA
    Nov 21, 2015
