P
Paul
I'm testing a new DMM I purchased, AM-240 by Amprobe. It claims *over*
100Mohm impedance in 400.0mV mode. So I charged a 4.7uF Mylar
capacitor to 36mV DC, and then placed the AM-240 (while in 400mV DC
mode) across the Mylar cap. After 25 minutes and 40 seconds it was
35..2mV. That comes to 14Gohms. So I thought it may be due to bias
current or offset voltage, and reversed the DMM polarity. Same
results. So then I charged the Mylar to 200mV. Same results.
Then, I measured the parallel resistance of my 4.7uF Mylar cap by
charging it to 184.8mV, disconnected the AM-240, and 1050 seconds
later connected the AM-240 and measured 177.1mV. That comes to
5.25Gohms, which is what I would expect from this capacitor. Actually,
for months I've been telling people my guesstimate for this cap is
5Gohms.
Anyhow, what kind of circuit are they using in this AM-240? It
appears as if it *resists* change! When it is disconnected it tends
to somewhat maintain the DC voltage, regardless of polarity. IOW, lets
say it's measuring the DC voltage on the Mylar cap, and it's 180mV.
Then one of the leads is removed. The AM-240 DC voltage decreases a
bit, not too much, but it slows down, and tends to hang around, say
160mV. If I reverse the polarity, to -180mV, the same thing happens
except it hangs around at -160mV. If the AM-240 was measuring say
35mV, and then disconnected, it tends to hand around at oh 20mV to
30mV.
Very interesting DMM. Not sure to like or dislike this.
Thanks for any info.
Paul
5Gohms.
30mV.
Paul
