Joshua K Drumeller
In college I had the wonderful and thrilling experience to design with
FPGAs. I have learned a lot working with them. However, the FPGAs we were
using were in pre-designed boards and we just focused on programming them
with our assignments. My question is how do you incorporate an FPGA into a
permanent design of a circuit board?
The FPGAs we used would lose their programming when the power was
disconnected. So how would a circuit designer who wanted to use an FPGA in
their permanent design get around that? Are there FPGAs which you can only
once from a computer then solder it into a design? Or would you have to
design a circuit which would load an FPGA every time it is powered up in
your permanent design? Or something else?
I have been searching the internet for some time and most of the info I get
is about FPGA experimental design boards. IF any one can help me out here it
would be extremely appreciated.
Josh
Josh
