FP 54 amplifier
Discussion in 'Electronic Design' started by Allan Adler, Aug 22, 2003.
  1. Allan Adler
    Allan Adler Guest
    On p.348 of Ramsey's book, Molecular Beams, he mentions something called
    a FP 54 amplifier. What is that? If it has gone the way of the dinosaur,
    what would be a modern replacement?
    Ignorantly,
    Allan Adler
    * Disclaimer: I am a guest and *not* a member of the MIT Artificial *
    * Intelligence Lab. My actions and comments do not reflect *
    * in any way on MIT. Moreover, I am nowhere near the Boston *
    * metropolitan area. *
  2. Phil Hobbs
    Phil Hobbs Guest
    The FP-54 was an electrometer tube from the 1930s. You're using this for a Langmuir
    probe or something like that, are you?
    If so, then depending on the sensitivity you need, you can use a CMOS op amp with a
    back-to-back parallel pair of diode-connected bipolar transistors in the feedback
    loop where the resistor usually lives, and connect the probe to the summing junction
    through a biggish resistor (not big enough to drop more than 100 mV at your design
    current, but big enough to protect the amplifier input. This will give you a
    logarithmic output. There are more accurate ways of doing it, if you have money to
    spend or a circuits guy available to help.
    Cheers,
    Phil Hobbs
