Four pin AND?
Discussion in 'Electronic Components' started by ehsjr, Mar 13, 2007.
  1. ehsjr
    ehsjr Guest
    Is there a 4 pin AND chip available?
    Something like this:
    +12 -----+
    [R] (external)
    +--- out
    -----o----
    | /c |
    inA o---| |
    | \e |
    | /c |
    inB o---| |
    | \e |
    -----o----
    Gnd-------+
    Ed
  2. That would be a NAND gate, eh? And I imagine you'd want some base
    resistors in most cases.
    There are very small gates like the following:
    http://www.toshiba.com/taec/components2/Datasheet_Sync//169/7277.pdf
    Or you could probably cob something together with a 6-pin transistor
    array..
    Best regards,
    Spehro Pefhany
  3. Jamie
    Jamie Guest
    a dual digital smt transistor?
  4. ehsjr
    ehsjr Guest
    Yes NAND - it would be nice if the base resistors were in
    the chip, but not required. Requirements changed from
    "when signal is present" to "when signal is present and
    clock is high" - the prototype was already made. Grumble.
    Ed
  5. Eg. Panasonic XP0431500L w/10K resistors, about 2mm square, but the
    TC7SZ00 is cheaper.
    http://www.semicon.panasonic.co.jp/ds/eng/SJJ00180BED.pdf
    Best regards,
    Spehro Pefhany
  6. ehsjr
    ehsjr Guest
    Nice. Thanks!
    Ed
