Tim_Hampshire
- Jul 13, 2012
- 2
- Joined
- Jul 13, 2012
- Messages
- 2
HI All,
My first post and a little about me.
Live in Hamphire in the UK and have worked as a compoutrer systems engineer for a number of years, I moved to mgmt a while back, so not really got my hands dirty much with a solderirng iron.
Anyway, to my problem at hand.
Have a TV which was not powering on. When power applied, the relay would tick.
Removed the PSU, and checked, and found that there were 3 Caps that were dooming, so replaced those, bit to no avail.
On closed inspection, I found that a Film Cap had bubbled on both sides and Cap Gel had leaked out, so pulled it off the board, and it had split underneath.
So, now I need to replace it, and this is my problem. I cannot locate this part ANYWHERE :-(
The part has the following markings :-
Carli .47K275V-X2 MPX40/100/21 250V and looks like a yellow 'lego' block.
I can submit rough dimensions if needed.
Looking at the location, the main AC comes in and there are 1 of these, a copper coil, another one of these, and another copper coil and finally this last one of these before hitting a relay.
I have another older flatcsreen TV that has a bust screen, and on checking, there are a couple that are similar however, markings show :-
HJC .22 microF MKP-X2 310-250v-
So not sure if these will work being a lower MicroF.
So, questions are:-
:-:- Can I use the above lower microF one
:- Can anyone point me to a company that sells the atual one i need.
Many thanks for your help
Tim
So, questions are:-
Tim
