Jamie M
I was thinking about focused ion beam for deposition/etching/cutting
material, I think if there is more than one type of element available,
ideally switchable in real time, this could allow for some neat
technologies, such as depositing layers of material for different
properties (semiconductors etc).. So I don't know if there are systems
out there already that can do this with multiple elements, but one
idea I had was to use an alloy or homogeneous source for the ions,
instead of a pure metal for the ion source, and atomize small amounts
off the surface of this with a laser to create ions. Then add a "mass
spectrometer" section into the ion accelerator path of the FIB (focused
ion beam) setup, and use the mass spectrometer to select which of the
elements from the ion source to deposit by changing the deflection coil
current in the mass spectrometer.
Another way to make a multi-element focused ion beam could be to have
small 1mmx1mmx0.1mm thick plates in a 2D chess board array, each of a
different element, and target a laser at the desired element to
vaporize a small amount to go into the ion beam. That method could
allow easier simultaneous deposition of elements with different masses
if there is more than one laser too.
cheers,
Jamie
cheers,
Jamie
