legg wrote:
There are many ways to maintain the insulation, for example split
bobbin. That's not really my concern because stuff can be potted up,
size is.
Well, I sort of admire the relaxed attitude, but it would probably
drive me crazy, if I was on the team. I like to see goals that are
demonstrably possible, even if just on paper, for some good reasons.
Yes, of course no 240V but we need headroom for the surges, and at the
DC peaks of those.
Suggest you nail down actual requirements, if you know you're possibly
testing the physical limits in the hardware being designed to do the
job.
My preference would be E-core and some newer materials start showing up
as E-cores, just not in the small sizes we need. It's like going into a
sporting goods store and all running shoes are 11 and up. No problem for
me but my wife would not like that.
It doesn't matter what core shape you use, unless the materials
exhibut remarkably lower core loss than the current leader
- ie ferrite.
Reports and specs on other materials talk about lower loss, but this
is a term used relative to other powder formulations only.
In the dimension limits stated; the use of bobbins over film
insulation will just make this worse.
Cost is not the prime parameter here as long as it isn't outrageous. And
that's what I am finding, the millisecond you want a custom size ferrite
and bobbin they charge through the nose. But, starting to look overseas
now. It could be like with taylored suits, something that is really only
affordable in Asia. To say it politely, right now I am a bit non-plussed
regarding the willingness of domestic companies to go out of their way
and make it happen. This would be "the" chance for one of those to get
into a cutting edge market.
If push comes to shove we could use a chip that does flyback-PFC at
several hundred kHz. But I haven't found such a beast yet, probably
because that usually result in an EMC nightmare.
For that matter, any converter chip designed for off-line critical
conduction mode could potentially be usable, whether intended for PFC
application or not. It won't cut down on real estate, unless you can
find an 8-pin part that has also migrated to leadless smd, that
requires less external parts to do the job.
About 100KHz operating frequency: In general, the simple CCM control
is constant on-time, variable frequency, with a limited upper
frequency (maximum power). Controllers likely try to limbo under
150KHz in order to avoid the CISPR/FCC pinch, making controller
tolerances and transformer inductance values a critical factor in
power transfer. That's going to be a headache in practice, without
margins - tough to provide in limited physical/thermal circumstances.
RTCA has it's own EMC requirements, with conducted emissions also
speced above 150khZ. It also has conducted susceptibility requirements
that go down to 10khZ, at current levels that may be significant in
lower powered devices.
Although I hesitate to advise actual use of power-integrated parts,
you may seem some interestink applications of 'linkswitch' parts, at
your targeted power level, at Power Integrations. LNK405-409(EL).
RL
