So i tried to make a flyback transformer circuit for some arcs of course. The circuit is with 555 timer astable which oscillates at 1khz frequency if i'm correct. Sadly it doesn't work. I'm thinking it could be the transistor which is 2SC5931. Other thing i'm thinking could it be that if you pull one pin out of the transformer could it damage the coil? And which coil to use for the circuit? I did it from this video
. I also used resistors in series because i didn't have 2.2k resistors. Thank you (I'm still a begginer FYI).
EDIT:I tried checking the transistor and it seems it isn't working.
