flux residue
Discussion in 'Electronic Repair' started by Roban Bieber, Sep 6, 2003.
  1. Roban Bieber
    Roban Bieber Guest
    Is there any problem with leaving flux residue on the circuit board after a
    repair?
    Roban
  2. Eric
    Eric Guest
    Brush it off with isopropyl alcohol, this is a great idea you might also
    spot fine solder shorts, that would be covered by flux.
    : Is there any problem with leaving flux residue on the circuit board after
    a
    : repair?
    : Roban
  3. Removal of the flux and inspection after doing so tends to produce a "more
    professional" appearing job. Realizing that it does take a bit more time,
    however, as stated, finding that little solder flake between traces or a
    poorly flowed connection could save aggrivation later?? Cheers
  4. Uns Lider
    Uns Lider Guest
    I've encountered boards with 20+ year old flux residue on them and no
    apparent problems, but it starts looking really ugly, so I clean it off.
    In high frequency RF stuff it might cause problems?
    -- uns
  5. CJT
    CJT Guest
    Might it capture moisture?
