Doug said:
OK guys...its sea story time! After several years of fighting florescent
desk lamps in US Navy HF receiver sites (110 VAC versions) using the turn
them off, get them out the building policy, I was shocked to see a new
construction building in Alaska having florescent fixtures being installed
in the ceiling. Not only that, but the Naval Research Lab was supplying the
fixtures as GFE (government furnished equipment). This was in 1970 and I was
very surprised to find out there exists special ballasts and fixtures for
florescent lights in radio reception areas. The diffuser cover over the
tubes had a very fine wire mesh laminated into the translucent material and
grounded to the fixture case. We powered up a fixture in the building and I
used a Stoddard NM25 RFI meter and swept the HF spectrum. The fixture was
quiet with the diffuser in place, and fairly quiet with the diffuser open.
Bottom line--there are at least 110VAC RFI reduction fixtures available. I
have no idea what the taxpayers paid for them.
73
Doug K7ABX
There are RFI eliminators that can be added to florescent lighting
fixtures, as an after-market upgrade. GE made all the ones that
I had installed in every Cannery Office in alaska. This was before
the advent of computer networks in the offices, and when that happened
we moved the radio's and antennas out away from the offcies and clear
out in the brush, and just left the Control Heads, back in the plants.
SEA 322's, 330's, and 325's work really well, at the end of 3000 ft of
telephone wire.
Bruce in alaska there is always a way to fix a problem, if money
isn't a part of that problem......
