Fluorescent lamps in series using electronic control gear?
Discussion in 'Power Electronics' started by seanspotatobusiness, Sep 8, 2019.
  1. seanspotatobusiness
    seanspotatobusiness
    193
    4
    Sep 11, 2012
    I would like to make a lamp using many small T5 fluorescent tubes (maybe 12 or 16). I would like to use a dimmable high frequency electronic control gear (not a starter and ballast). You don't seem to be able to get dimmable control gear for 6 W tubes. I was wondering if I could put four 6 W tubes in series and connect to a 14-24 W control gear? Then a 4x14-24 W control gear could power 16 6 W tubes. If the strike voltage needed would be too high then I could connect three in series instead.
  2. Bluejets
    Bluejets
    4,095
    859
    Oct 5, 2014
    There used to be twin series 20W fluro tubes controlled via 1 40w ballast and 2 starters of a particular rating (P2 if I remember correctly)
    However, you are dealing with an entirely different kettle of fish here in that electronic ballasts are 4 wire ( 2 to each heater at each end of the tube) and no way I know of that would get 2 tubes in series to strike correctly let alone 4.
  3. seanspotatobusiness
    seanspotatobusiness
    193
    4
    Sep 11, 2012
    Thanks. I suppose making my own dimmable high frequency control gear for 16 6 W fluorescent bulbs isn't feasible for someone with no background in electronic engineering? They don't seem to make dimmable control gear for wattages less than 14 and 14 W tubes are too long for my application.
  4. Harald Kapp
    10,070
    2,151
    Why insist on tubes? Use LEDs. These are easy to dim, easy to scale, no mercury.
  5. seanspotatobusiness
    seanspotatobusiness
    193
    4
    Sep 11, 2012
    LEDs flicker at a rate detected by video camera and high frequency control gear don't plus the LED tubes don't light up 360 degrees and my plan is all about aesthetics.
